#45323 - 06/11/2001 08:26 "Your player is not registered" on 2.0b3
I have had this a couple of times now. I try to run emplode and I get a message saying "Your player is not registered, please re-run the setup" (or something very similar). I then have to reinstall emplode before it will work again.
Edited by andy (06/11/2001 08:27)
#45324 - 06/11/2001 08:27 Re: "Your player is not registered" [Re: andy]
What version of the software are you using?
#45325 - 06/11/2001 08:28 Re: "Your player is not registered" [Re: tfabris]
2.0beta3 (I remembered I had forgot it and edited the subject line just as you were replying)
#45326 - 06/11/2001 09:32 Re: "Your player is not registered" [Re: andy]
No, you're not. You're attempting to run the v1.0 emplode. That message appears nowhere in the v2.0 source code -- mainly because v2.0 emplode doesn't care.
#45327 - 06/11/2001 10:07 Re: "Your player is not registered" [Re: Roger]
That is very strange. Both times I was running it I was running it from the Riocar program group and I had previously uninstalled v1.03 so I can't see how I could have been running the wrong version.
If it happens again I will try and work out how I can possibly be running the wrong version...
#45328 - 06/11/2001 10:18 Re: "Your player is not registered" [Re: andy]
Various versions of the software installed to different locations on your hard disk. Prior to 1.03, it was in a different place.
Scour your Add/Remove Programs panel for "Rio Emplode" "Rio Car Emplode" "Empeg Car" and anything similar, deinstall all of them. Then do a hard disk search on emplode*.*
#45329 - 06/11/2001 10:26 Re: "Your player is not registered" [Re: tfabris]
I did this before installing 2.0 the last time, which is why I am puzzled as to where the old emplode it being run from...
